Railbus for the PMR
steamer68
Re: Railbus for the PMR
Post by steamer68 » Thu Dec 21, 2017 1:38 pm
Jim I'm looking forward to seeing the electrics fitted and working mate. :thumbleft:
Post by philipy » Thu Dec 21, 2017 3:18 pm
Excellent Jim.
Just a thought, they might look better if the body mouldings were cotinued across the door? Possibly just the lower one?
daan
Post by daan » Thu Dec 21, 2017 4:11 pm
Those doors look like they belong there from the beginning. Great work!
Post by Peter Butler » Thu Dec 21, 2017 5:31 pm
Well done Jim, the door looks just the part there and perhaps a couple of steps beneath would finish it off nicely?
Post by Big Jim » Thu Dec 21, 2017 6:53 pm
There will be steps, but I haven't worked out if they will inset or proud. Like wise the moulding will continue over the doors. The bottom will be straight but I have not decided on the upper two, they may sweep downwards and join in a manner similar to the noses. The other thought is that they form into a lozenge shape.
Post by Big Jim » Thu Dec 21, 2017 11:37 pm
Something like this.
Sorry for the 'fag packet' (well rolling paper) diagram, but you get the gist.
The second design looks like the lining on the side of DELTIC to me.
Post by philipy » Fri Dec 22, 2017 3:09 am
Not wishing to denigate your skills Jim, but those look very nice but horribly complicated curves to duplicate and keep even. It would be a cryin shame to end up spoiling what you've already achieved. I'd say the KISS princple applies here (Keep It Simple S.....)
Post by bazzer42 » Fri Dec 22, 2017 7:35 am
Those doors look good. I have to agree with Philip that curves won't be easy. Perhaps a dry run on some scrap first. Although sometimes it is nice to push ourselves because when it works....
daan
Post by daan » Fri Dec 22, 2017 9:13 pm
If you make a guidance for the curves to help you get the shape even on all corners, I think it must be possible to get it right. But I think a normal straight line would look better. You already have the bent shape on the front and back of the engine.
steamer68
Post by steamer68 » Sat Dec 23, 2017 10:58 am
Jim the steps will be tricky to replicate but I'm sure you will do a great job no matter which design you decide to go for. :thumbleft:
RylstonLight
Post by RylstonLight » Sat Dec 23, 2017 2:04 pm
I think I would go for straight, however the drop curves are easy if you have a cheap plastic compass-cutter. This are available from Olfa, Rolson and some own brands (one page google search prices £3.xx to £6.xx).
I am sure expensive metal versions are better but I rarely use them so bought the cheap plastic type, but when I do need them I really appreciate even the plastic Olfa one I have. There is a knack to using them.
If you try to cut too deeply it twists and distorts the arc. But using shallow cuts I produced the same shape in 1mm ply for the front-trim for my observation coach. The same in thin platicard should be a doddle if it copes with the weft-and-warp of the ply. In fact I just remembered I did one in plasticard for a lining template for the observation coach trim.
Some sized lozenges can be produced quickly in thin plastic card by making a rectangle then using a paper-punch to nibble a quarter circle off each corner of the rectangle. I used this to produce “cast iron” maker’s plates for a plastic card water-tank for the RLR running shed
Post by Big Jim » Sat Dec 23, 2017 5:02 pm
Thanks for the suggestions. The doors have been filled again and so are now drying but I have managed to have a bash at the steps.
Post by tom_tom_go » Sat Dec 23, 2017 5:47 pm
Admire you determination Jimbo, I would of shelved this one by now!
Post by Big Jim » Sat Dec 23, 2017 6:49 pm
It has been tempting on many occasions.
markoteal
Post by markoteal » Sat Dec 23, 2017 10:10 pm
Nice steps - how do they line up with your platform heights?
IrishPeter
Post by IrishPeter » Sat Dec 23, 2017 10:57 pm
At this point I am hoping for the reply...
"PLATFORMS?"
Peter in Va
Post by Big Jim » Sat Dec 23, 2017 11:04 pm
I have always imagined the PMR to have very little in the way of platforms. Something rail height possibly but lots of little halts with nothing more than a sign.
Something that our colonial cousins call a flag line I think.
steamer68
Post by steamer68 » Sun Dec 24, 2017 1:00 am
Nice job on the steps Jim I admire your drive as I know you have had to start a fresh on some of the parts but its all paying Jim. :thumbup:
Post by philipy » Sun Dec 24, 2017 2:32 am
Steps look good Jim
Post by Peter Butler » Sun Dec 24, 2017 11:04 am
A pair of nice brass handrails will finish that off well.
