MHLR Extension
SillyBilly
mhlr
- Retired Director
SillyBilly
mhlr
- Retired Director
Well when the pond was casted, the trackbed was already built, and the pond had to come to ground level otherwise major groundworks would be needed, and because the site is sloped, the pond is higher than the rest. Because everyone is winging about it, and because I'm not happy with it, it looks like I'm going to have to work out a way of fixing the bloody problem. I was going to put a spiral in, but certain authorities said no.SillyBilly wrote:It translates in to what is in the way of not having it flat or spreading out the gradient?
looking at the video, I would say that it is possible to ease the gradient, I think that if you get long as straight as possible piece of wood (or maybe a long spirit level) you could put in on the grade and see if there is a "dip" into the grade, ie there is a shallow bit of grade before a significant steepening. You could then pack the track up to the level of the long bit of wood etc using bits of wood, or a concrete mix. Remember to work out gradients it is the length of the gradient divided by the height eg 100 cm divided by 4cm gives a gradient of 1 in 25
Hope you are able to fix it, I'd say on a straight bit of track the maximum gradient you would ideally want is 1 in 50, although you could push it steeper then this if really necessery
mhlr
- Retired Director
I aint going to say what I found the gradient to be, but its a 1 in 6.
Well, my dad and I have been discussing plans... To make the gradient less, like laalratty said, make it longer to ease it out a bit. So I will use this plank of wood as below, packed underneath with wood, or cement. It will also go a bit further down, than the wood is in the picture, so it eases the left fork too.
But my dad also has an idea himself... Instead of having the bridge from the curve out of the tunnel, going across the church, we eliminate that, and have the track coming off from the curve onto a wooden tressel section (illustrated where the sticks and string are), where there will be a large passing loop to serve as a steam up bay at steam ups, then leading to a single track leading along the edge of the wall, then crosses over a lift out bridge up that then leads across the flower bed next to the path, and levels to the top of the pond loop where there will be a set of points. This will then mean a complete circuit, and an easier way up for those that cannot make it up to the pond the other way.
- Dr. Bond of the DVLR
- Retired Director
Extention
Amazing to see such progress. I still think you should name that gradient or where it was 'The Kink' after the rediculous gradients on the W and LLR!!
Besides it looks as if you will benefit by getting more running track any way!
bungle80a
Not checked on this thread for a few weeks. Looks like you've been busy Pete! Shame about the gradient problem! It might be worth easing the grade out right far back as the step crossing! Obviously, keep the area (say a couple of foot each side) of the point level! Its strange how the earlier photos never reflected the gradient, or maybe thats just me!
Your dads suggestion seems to be a win-win situation! It irons out the incline problem (in 1 direction of travel) AND it means you get a bigger railway and steaming bays!
Its great to see expansion on your line Pete, and who knows, one day I might get to visit your part of the UK, and what visit to the South West wouldnt be complete without a visit to the MHLR?!?!
SillyBilly
bungle80a
mhlr
- Retired Director
I don't think I will go all the way to the step crossing, because I would have to raise everything eitherside of the trackbed too then (otherwise it wouldn't look right to me). Although I will consider it though, I will see what sort of gradient I get with that plank of wood resting ontop.bungle80a wrote:It might be worth easing the grade out right far back as the step crossing! Obviously, keep the area (say a couple of foot each side) of the point level! Its strange how the earlier photos never reflected the gradient, or maybe thats just me!
Yes it is, I was surprised he actually wanted to fund the building of that. I wasn't sure on it at first, I think it could look a bit of an eyesore, but hey, its his garden!!bungle80a wrote:Your dads suggestion seems to be a win-win situation! It irons out the incline problem (in 1 direction of travel) AND it means you get a bigger railway and steaming bays!
Yes, visit the MHLR if you come this way. Especially if its over the MHLRfest weekend (not as good as PTLRfest mind you!), as this year, if it goes to plan, Dan and Andy may make it down and we will carry on into the night, so plenty of action and videing going on
bungle80a
