Structures of the DVLR
Post by Narrow Minded » Sat Feb 18, 2012 6:48 pm
Any further progress Mr B. ?
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Sat Feb 18, 2012 10:19 pm
I've had them painted and should do a little more tomorrow!
Woodfields Light Railway
Post by Woodfields Light Railway » Sun Jan 19, 2014 8:14 pm
Judging by the fact that that post was posted 2 years ago, I guess it's painted now? :D
Post by Dr. Bond of the DVLR » Mon Jan 20, 2014 9:58 am
There did indeed get painted up and I placed them about but they quickly got damaged. I've done a lot of work with buildings for Woodbridge which I think I posted in my general topic. Perhaps I should have posted them here?
SapperAnt
Post by SapperAnt » Tue Jan 21, 2014 5:40 pm
Thanks for the inspiration to finish and repair some of my structures!!!
Ive made mine from polystyrene but covered with waterproof tile grout I then scribed to make rough stone or just left to represent render.
I'm experimenting with self adhesive floor tiles - of a s uitably sltate tastic texture and colour- to use as slates..........
steamyjim
Post by steamyjim » Wed Apr 09, 2014 11:12 pm
What paint did you use on the buildings? Clearly something that doesn't attack the polystyrene but stands up to outdoor use.
Post by Dr. Bond of the DVLR » Wed Apr 09, 2014 11:16 pm
Masonry paint for exteriors. White is used and then the colour I want is mixed by adding different amounts of various acrylic paints. A little sand is often added for texture.
steamyjim
Post by steamyjim » Wed Apr 09, 2014 11:31 pm
Mr. Bond of the DVLR:99169 wrote:Masonry paint for exteriors. White is used and then the colour I want is mixed by adding different amounts of various acrylic paints. A little sand is often added for texture.
Thank you! What about your windows and doors - do you buy them in or build them yourself?
Post by Dr. Bond of the DVLR » Wed Apr 09, 2014 11:41 pm
Doors are all strip wood glued onto plywood and windows are all manner of things from bits of cut up plastic crate to strip wood to bought ones. I am not very good at window frames If I am honest they are the weakest part
steamyjim
Post by steamyjim » Thu Apr 10, 2014 12:00 pm
Mr. Bond of the DVLR:99171 wrote:Doors are all strip wood glued onto plywood and windows are all manner of things from bits of cut up plastic crate to strip wood to bought ones. I am not very good at window frames If I am honest they are the weakest part
It's the bit that is putting me off getting around to my buildings. Building good windows seems like a lot of work for little actual progress! I'll just have to sit down at do it at some stage though. :cry:
kandnwlr
Post by kandnwlr » Thu Apr 10, 2014 5:52 pm
If you´re willing to apply the three foot rule, then budgie grit is a surprisingly effective alternative for modelling flint. Photos available ...
Then believe it or not, there is a dolls house materials supplier that does flint paper (like brick paper) - but I clearly not for leaving outside in the rain ....
